mtc_8
Mar 28, 2022Follower
srs60 wire connection
can i mix and match connections? between satelittes router and switch? i am adding a satellite to my system setup, i got a router srs60 connected directly by with wire to a satellite, and from the ...
Mar 28, 2022Guru - Experienced User
yes you can connect a satellite to the switch. Whenever I use satellites, I'm connecting through a switch.
