limesin
Aug 19, 2023Aspirant
SRX50 problem
Hi The router is down after the firmware update attempt. The DC led is black. The power supply has been checked and is ok.
Aug 19, 2023Guru - Experienced User
schumaku
Have also an SXS50 at hand? Plug it to the same power supply as in use (with power LED black) and check if the satellite does power up on the same power supply. Try the SXS50 power supply for the SXR50, too. This should make it clear which device is broken.
- limesinAug 19, 2023Aspirant
The power supply is ok. Checked few times. On SXS50 as well.
