limesin
Aug 19, 2023Aspirant
SRX50 problem
Hi The router is down after the firmware update attempt. The DC led is black. The power supply has been checked and is ok.
schumaku
Aug 19, 2023Guru - Experienced User
Correct 12V, 3.5A DC output power supply plugged?
No Power LED is unlikely coming from a failed firmware update. Could well be a hardware failure. Head to https://my.netgear.com/ - click your router (based on the serial number) and follow the (Request Hardware Support) process.
