kromonos's avatar
kromonos
Follower
Sep 18, 2019
Switch from router mode to ap mode?
I've a Orbi Pro setup here with following specs: Mode: Router WAN:  192.168.0.0/16 WLAN1: Active  WLAN2: Active Guest-WLAN: Active LAN config: 10.0.0.0/24   When I now switch to AP Mode, what...
  • JohnC_V's avatar
    Sep 20, 2019
    Hi kromonos,
    The configuration of the WLAN will still be there. The only thing that will be changed is that the DHCP/NAT function will be handled by your Router and also the gateway. The Orbi Pro has its own wireless separation from the Guest network to ensure that they cannot access anything inside your network.
    Welcome to our community! :)
    John
    NETGEAR Community Team
ProSupport for Business
