TheGrumpyGent
Dec 29, 2021Tutor
SXK80 - Allow printer on two VLANs?
Is it possible to share a device across VLANs? In my example, I have a WiFi printer I would like to make available to more than just one VLAN (i.e. allow it on VLAN 1 and VLAN 20). Is this possible...
schumaku
Dec 30, 2021Guru - Experienced User
Technically this does translate to have IP routing between the subnets, allow the VLAN 20 IP subnet accessible from the VLAN 1 subnet, and last but not least the unknown printer must be discoverable eg. by the ubiquitous WS-Discovery using Multicast, and for other printer drivers probably other discovery methods (where most like IP broadcast can't work between different IP subnets).
Netgear released a Beta version -> [In Beta] SXK80 Beta firmware version 3.2.5.778 for mDNS service - however the feature was not made available on newer firmware builds yet. BruceGuo when will this feature become available on production firmware for the SXK80 and the SXK30 Orbi Pro systems?
- TheGrumpyGentDec 30, 2021Tutor
Thank you for the details schumaku ! This makes sense; I'm a bit surprised this wasn't available yet - I know the Orbi Pro has a "reduced functionality set" to support smaller businesses with no IT department, but having a printer etc. available on more than one VLAN is pretty typical.
