vinions
Apr 03, 2023Aspirant
SXK80 Satellite issues with managed switch/VLANs
Stumped here. Here's my setup:
Currently running pfSense firewall router (via a mini PC) connected to a TL-SG1016DE managed switch with a SXK80 router and satellite system in AP mode. I have 4 VLANs (5 if you include VLAN1). set up. On the SXR80, I have 2 VLANs on 2 separate SSIDs while keeping the main SSID on VLAN1. WAN port is the trunk port connected to the switch (assigned with VLAN1 profile). I don't use the ethernet ports on the SXR80 for anything except to access the management UI.
Right now, everything works. I can surf and when I put up the appropriate block firewall rule in pfSense, it'll kill the internet as expected. Connecting to the SSID will yield the correct IP range based on the assigned VLAN profile.
I've come to a few problems though:
1. UI says no internet even though there clearly is.
2. Router lights up magenta.
3. Satellites light up magenta even though it's right next to the router.
4. Netgear insight app cannot find the SXR80, presumably because it "doesn't have internet"
5. Satellites are listed under Attached Devices. Appears to be linked to the router. But they do not show up under VLAN/Bridging so I cannot adjust the VLAN profile on the ethernet ports of each satellite.
6. Not sure if I'm reading this correctly but under Attached Devices, it appears that the satellites are connected directly to the router even though I have 1 router and 2 satellites in a straight line from the front of the house (router) to the detached garage (last satellite). Hence the last satellite has a "fair" connection and sometimes lose connection even though there is a satellite in between (shows good connection). The satellites are around 40 feet apart.
Does it work better if you make port 1 an untagged member of vlan 1 ?
My SXK50 does not create a bridge for vlan 1. It has a bridge for untagged traffic and separate bridges for each vlan profile connected to a wireless SSID so I don't think DHCP reply traffic would ever reach the satellites if I hooked up like you show.
- BasuKhodanapurApprentice
Hi vinions
Thanks for reaching Netgear community forum.
We need couple details.
1. Please share your network topology with vlan and pfsense configuration details should be visible.
2. And also, please share Pfsense firewall configurations.
I will try to help you with solution.
Thanks,
Basavaraj
- vinionsAspirant
Quick update. I decided to do something different. I factory reset the router and setup the satellites in router mode, updated the firmware, and changed the VLAN profiles on the satellite ports. Everything looked fine (except internet which I didn't try). But the moment I switch to AP mode, everything broke.
- Only two of the satellites showed under wireless devices but both had "config sync" under status.
- The third satellite for some reason showed under wired devices connected to one of the other satellites which is not true
- The satellites did not pull new IPs from the DHCP.. they were still showing the default 192.168.1.x
- This time, however, I was able to see the satellite ethernet ports under VLAN/Bridging. The VLAN profiles had reset but was able to change two sets back. The third (the "wired" one) was not connected.
I'm starting to think this is firmware related. It's basically a useless product if they're not going to fix this.
BasuKhodanapur See attached for topology. Thanks
Hivinions
Thanks for providing enough data.
As Animal7857 mentioned Please try this option => Does it work better if you make port 1 an untagged member of vlan 1?
I tried locally similar to your configurations except some firewall rules my network works fine in AP and Router mode.
Could you please try modifying firewall rule, just to isolate the issue.
Meanwhile I try some other configurations.
Thanks,
Basavaraj
