vinions
Apr 03, 2023Aspirant
SXK80 Satellite issues with managed switch/VLANs
Stumped here. Here's my setup: Currently running pfSense firewall router (via a mini PC) connected to a TL-SG1016DE managed switch with a SXK80 router and satellite system in AP mode. I have 4 VL...
- Apr 05, 2023
Does it work better if you make port 1 an untagged member of vlan 1 ?
My SXK50 does not create a bridge for vlan 1. It has a bridge for untagged traffic and separate bridges for each vlan profile connected to a wireless SSID so I don't think DHCP reply traffic would ever reach the satellites if I hooked up like you show.
vinions
Apr 04, 2023Aspirant
Quick update. I decided to do something different. I factory reset the router and setup the satellites in router mode, updated the firmware, and changed the VLAN profiles on the satellite ports. Everything looked fine (except internet which I didn't try). But the moment I switch to AP mode, everything broke.
- Only two of the satellites showed under wireless devices but both had "config sync" under status.
- The third satellite for some reason showed under wired devices connected to one of the other satellites which is not true
- The satellites did not pull new IPs from the DHCP.. they were still showing the default 192.168.1.x
- This time, however, I was able to see the satellite ethernet ports under VLAN/Bridging. The VLAN profiles had reset but was able to change two sets back. The third (the "wired" one) was not connected.
I'm starting to think this is firmware related. It's basically a useless product if they're not going to fix this.
BasuKhodanapur See attached for topology. Thanks
Animal7857
Apr 05, 2023Guide
- BasuKhodanapurApr 05, 2023Apprentice
Hivinions
Thanks for providing enough data.
As Animal7857 mentioned Please try this option => Does it work better if you make port 1 an untagged member of vlan 1?
I tried locally similar to your configurations except some firewall rules my network works fine in AP and Router mode.
Could you please try modifying firewall rule, just to isolate the issue.
Meanwhile I try some other configurations.
Thanks,
Basavaraj
Hi vinions
Can you please share the packet capture when issue occurs .
Orbi has option to run packet capture.
1. Open Orbi ip address/debug.htm and enable Lan/wan packet capture. It will prompt for username and password. Please enter your login credentials
2. Start capture then start to recreate the issue and then click on Save Debug Log debug logs will be shared to your system.
3. Please share the logs
Refer attached screenshot.
Thanks,
Basavaraj
- vinionsApr 06, 2023Aspirant
Thanks BasuKhodanapur and Animal7857 for your help. Turns out it was exactly the VLAN1 untagged issue. Once I untagged VLAN1, everything was reading correctly.
The other issues outstanding are probably related to firmware which I can live with for now. The satellites keep losing connection until I downgraded the firmware and seemed to stabilize though time will tell. Also, When I switched from router to AP mode with a fixed IP, it will not detect internet, but if I stayed with DHCP (and then do static IP mapping), it detects internet fine.
