shejialun
Aug 11, 2023Aspirant
SXK80 - Satellite synchronization issues
I'm having an issue where after I first changed the SSID and password for the SXR80 after restoring the factory, then it fails when setting up the Orbi satellites, but it succeeds when setting up the...
schumaku
Aug 11, 2023Guru - Experienced User
shejialun wrote:
Is it possible to change the SSID and password after setting up the Orbi satellite?
Only system-wide, the config with the SSIDs and the admin password is sync'ed all over.
- shejialunAug 11, 2023Aspirant
Hello schumaku,
I can actually normal my satellites synchronize the router settings properly, but I've never been able to add the SXS80 device in INSIGHT.
- schumakuAug 11, 2023Guru - Experienced User
shejialun wrote:
Hello schumaku,
Yes, these are the subtle differences on the Orbi Pro WiFi 6 system operations on Insight. It's not integrated as sleek as all the supported switches and WAX6xx. Do as advised please.
