GMoGoody8
Jul 31, 2022Luminary
SXK80 5Ghz Bandsteering
In my environment there is a lot of interference so it’s nice to be able to analyze it and configure my SXK80 to get optimal performance. I noticed the other day my more capable 5 GHz devices were ...
DaneA
Aug 08, 2022NETGEAR Employee Retired
What is the current firmware version of your SKX80? If ever its not yet the latest version, I suggest you to update it then observe if the same problem will occur. The latest SXR80/SXS80 firmware is v4.2.1.120 and you can download it here.
DaneA
NETGEAR Community Team
GMoGoody8
Aug 18, 2022Luminary
DaneA ,
Loaded 4.2.1.120 and still seeing the same issue. All 5Ghz higher bandwidth clients are being steered to channel 157 which is the automatically selected 5Ghz channel but in my environment has a lot of interference. Then all 5Ghz lower bandwidth clients are on the user selected channel 40.
- DaneAAug 23, 2022NETGEAR Employee Retired
Just want to verify. Does your Orbi Pro network only consists of 1 SRX80 router and 1 SXS80 satellite or you have more than 1 SXS80?
Also, whenever you observe that your laptop is getting 300-400Mbps instead of 600+Mbps when connected to the 5GHz SSID, if you login to the web-GUI of your SXK80 then check on Attached Devices, to which Orbi Pro device is your laptop connected to? Is it to the nearest router/satellite or to the other satellite that is further away?
DaneA
- GMoGoody8Aug 24, 2022Luminary
" Does your Orbi Pro network only consists of 1 SRX80 router and 1 SXS80 satellite or you have more than 1 SXS80?"
I have a 1 Router and 2 Satellite setup in a three floor townhouse all connected with unmanaged 1Gb switches for ethernet backhaul.
"Also, whenever you observe that your laptop is getting 300-400Mbps instead of 600+Mbps when connected to the 5GHz SSID"
Always connected to closest Orbi before I run a speed test. Usually line of sight 10 -15 feet- DaneAAug 25, 2022NETGEAR Employee Retired
Thank you for your response. 🙂
Just to verify. Are all SXS80 satellites connected directly to the unmanaged switch? Are the satellites paired wirelessly or are you using wired backhaul? If ever you are using wired backhaul, you can just unpair the satellites from the SXR80 router and verify if the speed improves.
Regards,DaneA
