GMoGoody8
Jul 31, 2022Luminary
SXK80 5Ghz Bandsteering
In my environment there is a lot of interference so it’s nice to be able to analyze it and configure my SXK80 to get optimal performance. I noticed the other day my more capable 5 GHz devices were ...
DaneA
Aug 25, 2022NETGEAR Employee Retired
Thank you for your response. 🙂
Just to verify. Are all SXS80 satellites connected directly to the unmanaged switch? Are the satellites paired wirelessly or are you using wired backhaul? If ever you are using wired backhaul, you can just unpair the satellites from the SXR80 router and verify if the speed improves.
DaneA
NETGEAR Community Team
DaneA
Aug 30, 2022NETGEAR Employee Retired
Thank you for your response. I understand that you have already did tests on your own.
I wanted to know if the speed will improve when using ethernet backhaul as the network setup: SXR80--unmanaged switch--SXS80. Let us try the ethernet backhaul setup and kindly check if the speed improves.
If the same issue occurs, I advise you to open a support ticket with NETGEAR Support here at anytime for further investigation. You may include the link to this thread as well as attach the results of the tests you did to isolate the problem.
DaneA
