GMoGoody8
Nov 08, 2021Luminary
SXK80: Allow Specific Client/s across VLAN
I have the SXK80 for my home since I really wanted the VLAN feature set and especially network isolation between my main LAN and IoT. I know in the settings I can disable network isolation comple...
- May 10, 2022
BruceGuo it's actually pretty amazing. From my tests, I can keep network isolation on for the source vlan and access still works. Further, the gateway is doing single direction resolution. In the past, I've tried to use the avahi gateway but ran into issues with it essentially echoing back to hosts their own name which causes Apple produces to change their name to "some device (123)" and on macOS display a dialogue about the name being taken. This resolves that.
So, it looks like the gateway is discovering devices according to the Shared Service Type, creates iptables prererouting/redirect rules, and then relaying the broadcast? This is far better than what was done before and I'm impressed.
The only thing I'd ask to change is that the dropdown for services is someone restrictive. AFP is dying, AirPlay and Chromecast are good as are scanners and printing, but there should be a middle ground before hitting "All Services". For example, HomeKit is missing which is probably the second most used behind AirPlay/Chromecast. I would suggest giving people a custom option to add something like "_scanner._tcp", "_sonos._tcp", or whatever else.
Anyways, tomorrow I'll finally move my IoT devices off to their own VLAN and begin long term testing.
Once again, great work and thanks BruceGuo
GMoGoody8
My Bad. I had searched and didn't see anything that matched my question 100%. Must have missed it.
Thanks for filling me in.
BruceGuo
Nov 14, 2021NETGEAR Expert
Hi
Can you check if this firmware works for your need? (by default, it allows mDNS traffic across subnets). 1 user replied it works.
Thanks
Bruce
- GMoGoody8Dec 11, 2021LuminaryBruceGuo was there supposed to be a posted FW or were you asking if my current FW works and supports mDNS,
Firmware Version V3.3.0.122- BruceGuoDec 12, 2021NETGEAR Expert
Sorry. I didn't menion the firmware. We posted beta firmware with mDNS support.
- architeFeb 05, 2022Star
Is it possible to downgrade to the beta from V3.3.0.122? Will this be updated in the future? I just got my setup this week and didn't realize what a pain this would be without it and this is deciding whether I ship back and go with another system.
Thanks!
