stingray777's avatar
stingray777
SXK80 Orbi sate how far apart from each other in rectangular building?
We have a long building about 410 feet, because we are extending it. So it is not in square shape, but long rectangular shape. Should I place the router and satellites about 50 feet apart from each other to get decent signal? Or even less apart and more satellites?
The building has a small office space about 25x75 ft on one end. That is where the server/network room is.
The whole building is going to be about 410x75 ft. We have one set of older Orbi to cover the office section and about 100 feet of the warehouse. I just purchased Orbi Pro WiFi 6 Tri-band Mesh System (SXK80). I am wondering how many satellites I need to purchase. They will be daisy chained in one direction (not in circular shape)
Orbi Router1 (AP) --- Satellite 1 --- Satellite 2 --- Satellite 3 --- Satellite 4 --- (Satellite 5?)
The new Orbi router is going to be in Access Point mode.
Another question is: Should I buy one more set of Orbi Pro WiFi 6 Tri-band Mesh System (SXK80), instead of more satellites, for better experience? Then I will not have to daisy chain as many satellites - two Orbi access points with maybe 2 satellites each.
Orbi Router1 (AP) --- Satellite 1 --- Satellite 2     Orbi Router (AP2) ---- Satellite 1 --- Satellite 2
I am going to have hub switches also, because the building is more than 300 feet long, and they are daisy chained to cover the whole 410 feet.
I hope I have described the situation clearly.
Please advise.
  • CrimpOn's avatar
    CrimpOn
    Installing two Orbi routers (base units, even if they are in Access Point mode) creates two separate WiFi networks.  Because they are in Access Point mode, every device on the network will be in the same IP subnet.  Even if both WiFi networks have exactly the same WiFi credentials (SSID/password), WiFi devices will not "roam seamlessly" between them.  So, as a person walks farther and farther away from the office, the WiFi signal will get worse and worse until the point that the device "gives up" and looks for a new connection.  "Aha!  Here's one with WiFi credentials that I know!"  The 802.11 standards that facilitate fast roaming will not function across more than one network.
    As there will be Ethernet wiring down the length of this building with switches placed at various locations, I would suggest deploying one router plus a number of satellites.  If the switches are "Daisy chained" down the building (to keep each Ethernet link well under 300ft.), each satellite can be connected to a different switch.  There is no need to Daisy Chain the satellites.  As far as the router is concerned, they are all connected over Ethernet.  (The router knows nothing about Daisy Chain anyway.)
    Distance between satellites is a fascinating question.  Personally, I'd buy 2-3 100ft. Ethernet cables (under $20 ea. on Amazon) and see what happens when satellites are spaced 50' apart.  Then 75' apart. Then 100' apart.  How do WiFi devices behave as you roam around the space?
    • stingray777's avatar
      stingray777
      Thank you for your response. I am not clear on this portion of your comment:
      Are you talking about Orbi satellite? I did not think they can be connected to a hub switch. I am confused. Orbi satellites are daisy chained wirelessly, right?
      I am not too worried about walking users. I am more concerned about speed and stability when I daisy chain 3 or 4 Orbi satellites (+Orbi Router/AP)
      • CrimpOn's avatar
        CrimpOn
        Netgear recommends no more than two satellites in a WiFi Daisy Chain:
        https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
        The reason is that all Daisy Chain WiFi transmission is on the same WiFi frequency and all WiFi is "one radio talks, everybody else listens".  When data goes from the router to the first satellite, that satellite and every other satellite cannot talk.  When it goes from the first to the second, the second satellite and the third satellite both have to listen.  Going from two to three same thing happens.  To make hops from satellite two to three (or four) means that the data has to be repeated over and over, eating up more and more bandwidth.
        Yes, Orbi satellites connect to the router and to each other over WiFi unless the user connects them with Ethernet cable:  Here is one description by Netgear:
        https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
        Ethernet connection is inherently Full Duplex, where data can flow in both directions at the same time. and it takes up zero WiFi bandwidth.  What I envision is:
        Router to switch #1 over Ethernet.
        Switch #1 - one cable to satellite #1, another cable to switch #2.  Other cables to whatever else needs service.
        Switch #2 - one cable to satellite #2, another cable to switchc #3. Other cables to whatever else needs service
        Switch #3 - one cable to satellite #3, another cable to switch #4. Other cables to whatever else needs service.
        Switch #4 - one cable to satellite #4, another..... and so on.
        If satellites provide adequate coverage with 75 ft. apart, it would take 4 total.  If they cover 100ft (50ft. each with no overlap), then only three.
ProSupport for Business
