timecode
Aug 12, 2022Guide
SXK80 Satellites turn pink as soon as I use VLAN tagged network
SXK80 in AP mode with 2 satellites (Latest firmware V4.2.1.120) - VLAN tags provided by pfsense router. (VLAN30 and VLAN50) - smart switches throughout (Trunked and tagged appropriately). VLAN setup...
- Jun 23, 2023
ETA for FW release is end of July.
timecode
Aug 20, 2022Guide
Hi DaneA,
Ok, have performed full factory reset on all units. Re-setup in AP mode which was auto detected.
I added one secondary wifi network with factory vlan flag (20). I left the factory vlans intact and did not add any others. There is no other changes. No changes to any of the port settings.
As soon as I join the secondary wifi network that is tagged with vlan, satellites turn pink and then network falls over.
Doing a simple ping to router/gateway shows as getting a response for a few replies and then nothing.
As soon as I disconnect from secondary wifi network and rejoin main wifi network satellites turn blue and network stability returns.
So no difference has occurred from full reset.
RaghuHR
Aug 20, 2022NETGEAR Expert
Hi timecode Could you please share the debug logs from both router and satellites?
Go to
https://<ip address of router/satellite>/debug.htm
and save debug logs when issue happens.
You can upload the debug logs into any cloud storage and send me PM to download the link.
Thanks,
Raghu
