timecode
Aug 13, 2022Guide
SXK80 Satellites turn pink as soon as I use VLAN tagged network
SXK80 in AP mode with 2 satellites (Latest firmware V4.2.1.120) - VLAN tags provided by pfsense router. (VLAN30 and VLAN50) - smart switches throughout (Trunked and tagged appropriately). VLAN setup...
- Jun 23, 2023
ETA for FW release is end of July.
hnagaraju1
Aug 07, 2023Guide
Other than SXK80/50/30 that work in router as well as AP mode.
NETGEAR has multiple WAX6xx series of APs, WAX200 series of APs that support VLAN per SSID tagging.
depending on your usecase, one of these should fit well with the solution.
If you have PFsense router. Here are the options
PF-senserouter/gateway====Poe+Switch=====WAX6xxx. (WAX610/WAX620/WAX610Y etc). (supports wired/wireless backhauls. Easy to setup with Insight cloud UI. needs more skills to set up wireless backhauls via AP's local UI)
PF-senserouter/gateway=====Poe+Switch====WAX214v2/WAX220 (PoE APs, wired backhauls only)
PF-senserouter/gateway=========WAX202/206 (desktop APs, wired backhauls only)
PF-senserouter/gateway=========SXR80(in AP mode) (supports wired/wireless backhauls. easy to setup with locl UI)
cmprmsd
Aug 17, 2023Initiate
I'm looking for this beta release as well and would like to join the beta group of possible.
Same problems with AP mode and VLANs configured in combination with an OPNsense firewall.
Also I wonder if there will be an update to remove the need of a full router and satellite restart, when any VLAN is changed. This will disconnect all clients and satellites if the network configuration is not fully static. I'd expect this from a business product.
Thanks in advance!
Thanks in advance!
