whatever11
Jun 21, 2023Initiate
SXR-80 No longer to access 1 SSID for some devices
I have been using my Orbi for years in the same location, same network and no new devices added for months. I had to reboot the router and now many of my IoT devices can no longer connect to the IoT...
KevinLiT
Jun 26, 2023NETGEAR Moderator
Hello whatever11 ,
I understand that there has been no change in network configurations prior to your reboot on Monday. Please remove/forget the network for the IoT devices that failed to connect, then install them back on the network.
Best,
Kevin
Community Team
- whatever11Jun 26, 2023Initiate
I rebooted the router 4-5 times and it fixed it. Clearly reboot (both with power off and through Insight) does not clean the cache/data as well as it should
It works now
