aafa760
Apr 07, 2022Aspirant
SXR30 Satellite using backhaul over Ethernet will not auto upgrade firmware
My SXr30 and the SXS30 that is Wireless Connected Satellite will auto upgrade firmware. But my 1 Satellite connected via Ethernet Backhaul will not seem to auto upgrade. Anyone seen this ? Rega...
Apr 07, 2022Guru - Experienced User
How is the SXS connected to the SXR? directly to the back of the SXR or is there a patch panel or LAN switch in between?
- aafa760Apr 08, 2022Aspirant
SXS30 is connected via switch.
Should it be plugged into SXR30 directly? if so then Lan configuration would need to be default for that port correct ?
Bryan
- JeraldMApr 18, 2022NETGEAR Employee Retired
Hi aafa760,
Just want to follow-up if you already tried connecting the SXS30 directly to the SXR30 via Ethernet cable and if that auto-upgrades the firmware.
Also, the LAN configuration should be fine with its default settings.
JeraldM
NETGEAR Community Team
- nitropowerApr 21, 2022Tutor
Does it matter the speed of the connection? 10mib ok? trying to get it to 100mib or 1 gb
Will test this this weekend.
- FURRYe38May 05, 2022Guru - Experienced User
What is the brand and model# of this switch?
What CAT# LAN cables are you using? CAT6 is recommended.
I'm currently using my SXK30 in AP mode. SXS30 is connected to the SXR with NGs GS-105/108 series switches in between.
aafa760 nitropower- nitropowerMay 05, 2022Tutor
Netgear GS724TPP Switch.
no vlan tags on ports
Any way I was able to connect all the sat via wireless and all is working as described.
I will revisit this when the new classrooms are finished they will be cat 6 connected to the switch or Directly to the Router.
