aafa760
Apr 07, 2022Aspirant
SXR30 Satellite using backhaul over Ethernet will not auto upgrade firmware
My SXr30 and the SXS30 that is Wireless Connected Satellite will auto upgrade firmware. But my 1 Satellite connected via Ethernet Backhaul will not seem to auto upgrade. Anyone seen this ? Rega...
aafa760
Apr 08, 2022Aspirant
SXS30 is connected via switch.
Should it be plugged into SXR30 directly? if so then Lan configuration would need to be default for that port correct ?
Bryan
JeraldM
Apr 18, 2022NETGEAR Employee Retired
Hi aafa760,
Just want to follow-up if you already tried connecting the SXS30 directly to the SXR30 via Ethernet cable and if that auto-upgrades the firmware.
Also, the LAN configuration should be fine with its default settings.
JeraldM
NETGEAR Community Team
- nitropowerApr 21, 2022Tutor
Does it matter the speed of the connection? 10mib ok? trying to get it to 100mib or 1 gb
Will test this this weekend.
- nitropowerApr 27, 2022Tutor
Jerald
I direct connected the sat using network back haul to the router so next firmware update we will see if it connects to the router,
in the advanced admin section about firmware update it still has not connected to sat2.
I was able to login to sat 2 and update firmware manualy
Bryan
- nitropowerMay 04, 2022Tutor
UPDATE
The connection from Router to Sat is now direct no switch and the VLAN/BRIDGE setting for the two router lan ports used in the network.
set for Default1 the Wireback haul now shows connection and firmware at correct levels.
Bryan
- BruceGuoMay 04, 2022NETGEAR Expert
Do you think the switch caused firmware upgrade not working?
