eljejer
Mar 23, 2023Aspirant
SXR50 router solid magneta
Since a couple of days (maybe since the latest Insight update on March 17th?) the LED bar on the router is solid magneta. Ans also "Basic", "Home" in the router's web interface says: "Internet Err...
- Mar 23, 2023
Hmm, I cannot remember switching the cable <FRIT!ZBox modem to Orbi router> from WAN to LAN port in the Orbi router.
But when I switched it back to the WAN port in the Orbi router, both the magneta light and the error message disappear
See https://community.netgear.com/t5/Orbi-Pro-Beta/SXR50-Beta-firmware-4-3-0-139-bugs/m-p/2268610#M74
Mar 23, 2023Guru - Experienced User
Fritzbox usually makes modem/router combo devices. do you have the SXR's ip address set in the fritzbox's DMZ?
Or the fritzbox in passthrough only mode?
it wouldn't be the first time an ISP update made an issue with an old setting on the gateway
- eljejerMar 23, 2023Aspirant
Reading this:
https://en.avm.de/service/knowledge-base/dok/FRITZ-Box-7590/131_Setting-up-a-DMZ-with-the-FRITZ-Box/
I understand that FRIT!ZBox does not support DMZ.
Nor is the Orbi router defined a an "exposed host" on the FRI!ZBox.
Do you mean to say that it SHOULD be defined as such for the (kind of) error message to disappear?
Also, when enabling Passthrough (see attached screenshot), the "error" remains. That is, if you mean PPPoE with "Passthrough only mode"?
