eljejer
Mar 23, 2023Aspirant
SXR50 router solid magneta
Since a couple of days (maybe since the latest Insight update on March 17th?) the LED bar on the router is solid magneta. Ans also "Basic", "Home" in the router's web interface says: "Internet Err...
- Mar 23, 2023
Hmm, I cannot remember switching the cable <FRIT!ZBox modem to Orbi router> from WAN to LAN port in the Orbi router.
But when I switched it back to the WAN port in the Orbi router, both the magneta light and the error message disappear
See https://community.netgear.com/t5/Orbi-Pro-Beta/SXR50-Beta-firmware-4-3-0-139-bugs/m-p/2268610#M74
KevinLiT
Mar 23, 2023NETGEAR Moderator
Hello eljejer,
Thank you for your post!
I understand that you are seeing errors in your router web interface that states "Internet Error. Not Connected". Your network configuration has been working since you switched the ethernet-connected port from the LAN to the WAN. Since this error occurred after the most recent update please factory reset your Orbi and then verify if the error message is present.
Best,
Kevin
Community Team
- eljejerMar 23, 2023Aspirant
Hello Kevin,
I don't quite understand;
you mean to say that I should perform a factory reset, despite the fact that the error message is gone now, after I switched the cable between router en Orbi AP port from LAN to WAN? Please explain. Thanks!
- KevinLiTMar 23, 2023NETGEAR Moderator
Hello eljerjer,
I thought that you switched the ports and it was still getting the error. Since the only thing that changed was the update then the thought is to factory reset the system so that it can clear all configurations and start on an empty slate. However, since the issue is gone there is no need to proceed with that troubleshooting path.
Best,
Kevin
Community Team
