DeadlyHifi
Oct 18, 2021Guide
SXR80 - Network drops on Voice/Video (zoom etc)
Hi all, I'm hoping you can help as I have a odd isue that is driving me mad - I don't even know for sure it's the router. I've been having periodic freezes on my zoom calls, Teams calls etc....
- Dec 29, 2021Hi all. I have solved the problem for me. I had the Orbi originally doing the pppoe - I've since switched this off and put it on to a router modem provided by the ISP. Since I've done that and the Orbi is no longer performing the authentication the problem is solved. I've no idea on why or how but that's the experience I've seen.
Thanks all.
DeadlyHifi
Nov 04, 2021Guide
I'm not massively technical but I have been watching the task manager throughput and what I see is a drop to zero on the receive data. Then a quick spike and catch up. Like the door was shut for a second.
RaghuHR
Nov 08, 2021NETGEAR Expert
Hi DeadlyHifi portishead quagmire1
Do you know the ping delay when you hit the issue? Could you please share the debug log at the time of the issue? You can run the ping to internet and see if there is any signficant delay when you see the drops. PM me the logs to downloads.
Thanks,
Raghu.
- DeadlyHifiNov 10, 2021Guide
hello. I've just been monitoring. When this happens my ping sees a timeout. So appears all connectivity from the machine drops.
- BruceGuoNov 10, 2021NETGEAR Expert
Hi All
would any of you who has the issue send me debug files via PM? I will ask eng team to import your config and reproduce it to see if it is triggered by specific features.
Thanks
Bruce
Hey Bruce. Can you walk me through the steps please and I'd be happy to.
Thanks
