yazun
May 25, 2021Aspirant
SXR80 and SXS80 ethernet backhaul via 1Gb hub/switch not working
Hello, I am unable to connect SXR80 and SXS80 via 1Gb ethernet hub. topology: ( cellar: modem)->(other room: router)->(cellar:hub)->(yet other room: satellite) When connected directly it wo...
RaghuHR
May 26, 2021NETGEAR Expert
Could you please let us know the model of hub that you are using?
yazun
May 26, 2021Aspirant
Certainly, tried two:
1. old 1Gb no-name (Level-one) hub (that supports jumbo frames though)
2. TP-Link AC1750
- yazunMay 28, 2021Aspirant
Can anything be done?
Otherwise will have to return the set and look for alternatives..
Regards
- RaghuHRMay 28, 2021NETGEAR Expert
We dont have any known issue. I am not sure your (cellar:hub). Did you check with any other switch?
I checked with two already that are proven to work with stable 1Gb links.
Even now these are shown to be wired - what's peculiar - via satellite, even both router and satellite are connected via the same hub.
