yazun
May 25, 2021Aspirant
SXR80 and SXS80 ethernet backhaul via 1Gb hub/switch not working
Hello, I am unable to connect SXR80 and SXS80 via 1Gb ethernet hub. topology: ( cellar: modem)->(other room: router)->(cellar:hub)->(yet other room: satellite) When connected directly it wo...
yazun
May 26, 2021Aspirant
Certainly, tried two:
1. old 1Gb no-name (Level-one) hub (that supports jumbo frames though)
2. TP-Link AC1750
yazun
May 28, 2021Aspirant
Can anything be done?
Otherwise will have to return the set and look for alternatives..
Regards
- RaghuHRMay 28, 2021NETGEAR Expert
We dont have any known issue. I am not sure your (cellar:hub). Did you check with any other switch?
- yazunMay 28, 2021Aspirant
I checked with two already that are proven to work with stable 1Gb links.
Even now these are shown to be wired - what's peculiar - via satellite, even both router and satellite are connected via the same hub.
- yazunMay 31, 2021Aspirant
Hello Raghu,
I poked into the logs and could not see any activation of the ethernet ports so I reconnected all the cables over the weekend and indeed the satellite started to show on the wired section as well!
Hard to think that I made a mistake somewhere but looks like it was the case, so big thanks for the follow up, your time helping was very much appreciated.
Cheers,
Chris
