seatek
Oct 17, 2022Aspirant
SXR80 and SXS80 Firmware update question to 4.2.3.102
Hi! Loving the AX6000 system. The Insight app said the new firmware version was available. The Insight cloud website also said the new firmware version was available. When I hit the Update bu...
- Oct 18, 2022
Yes! It appears that disabling the VLAN feature on Wireless Network 3 (unchecking the box and hitting Apply), waiting for the router to restart, then going back and re-enabling the VLAN feature on Wireless Network 3, fixes the connectivity issues associated with Wireless Network 3 internet connectivity issues mentioned in the firmware release notes.
All better now. Thanks yet again!
Mark
seatek
Oct 18, 2022Aspirant
A fix for the Wireless Network 3 problem in the firmware release notes is to disable the VLAN feature, or to "reload the configuration", whatever that means.
I will try to disable the VLAN feature, and then re-enable it. Perhaps that will be "reloading the configuration" enough?
seatek
Mark
