freer
May 19, 2021Guide
SXR80 Can’t Obtain IP Reliably After Power Cycle
I just purchased the Orbi Pro SXK80 (comprised of the SXR80 and a single SXS80). Since I have owned it, I have been doing work on the house and have had to flip the breaker at least once a day. Thi...
schumaku
May 19, 2021Guru - Experienced User
Already considered that a cable modem can require several several minutes to start-up, to negotiate down- and uplink, and receiving the carrier configuration? Before doing so, these cable modems offer an "own" local network before configured, a router can pick up this config (like a computer used for troubleshooting), and you won't be able to reach the Internet - cumbersome this won't "change" after the modem is fully deployed.
With the mesh systems, there is additional complexity involved what might again require a stacked/delayed start-up.
- freerMay 19, 2021GuideFor a product that touts being capable for small to medium businesses, having to manually intervene at all is almost unacceptable. Could you imagine if these were actually installed all over the house with the wall mounts it came with? Would I literally need to get a ladder out to power cycle these manually each time there was a power outage? Where is that in the marketing?
All of that aside, I’m following the instructions as they are laid out in the troubleshooting section in the manual on page 160, and it hasn’t been able to reliably get me back online. My modem consistently comes back up (all LEDs show solid) within 1 minute every single time. As I mentioned earlier, I wait 2-5 mins before even plugging the Orbi Pro in, and it still fails. It never resolves automatically. If I let it sit overnight it will not resolve.
The Insight app continues to show the previous IP it had prior to turning off the power. It’s not until I poke around in the web UI that I see 0.0.0.0.- freerMay 21, 2021GuideI called into support again (case 44595082) and spent an hour and a half on the phone. definitely one of the worst support experiences i have ever had. they refused to entertain the idea that the unit was defective. they claimed that they couldn’t replace it without first having a computer hardwired into the modem. this is a completely unrealistic ask in these times - all of our computers don’t have ethernet jacks (macbook pro, lenovo thinkpad). their only advice was to find someone who had a computer with an ethernet jack! what a joke!
- AquaLabAquariaMay 22, 2021Guide
Just wanted to post to try to provide some help as I have been dealing with frustrations with this router as well, but I still think it has potential.
Have you tried doing a factory reset on them all? I know it will be annoying, but it resolved some major issues I was having after playing with settings that likely caused my issue. I got smart after that one and started backing up my configurations as I added more and more configs. That way, if you find yourself with the Orbi acting wonky again, you got a back up to get you back up and running fast after another reset.
I recommend you do that and then make sure to start backing up methodically as you work on things. You'll be happy you did!
The Orbi Pro 6 I got does still have some issues (wireless devices showing up as ethernet connected when using ethernet backhaul) that I hope will get resolved, but otherwise it is a pretty powerful feature set for an entrepreneurial crew who don't have dedicated IT! The VLANs are great, but I do wish the documentation and nuances of the set ups could be covered better in the documentation.
