freer
May 19, 2021Guide
SXR80 Can’t Obtain IP Reliably After Power Cycle
I just purchased the Orbi Pro SXK80 (comprised of the SXR80 and a single SXS80). Since I have owned it, I have been doing work on the house and have had to flip the breaker at least once a day. Thi...
GMoGoody8
May 25, 2021Luminary
I'm really curious here and perhaps I have to do more testing but do not want to rock the boat due to my initial experience. I too was not happy with this exact issue.
I upgraded from the residential AC3000 RBR50 to SXR80. During initial setup it took many reboots of the S33 modem and the SXR80 until I had WAN connectivity where the RBR50 came up with WAN on the first try.
Not sure if it's the 2.5Gb negotiation as this was the first time I have had 2.5Gb on both the Modem and Router. The Ethernet Cable is Cat6A and tested to be wired correctly.
| WAN | 2500M/Full |
It finally took but I am very concerned with upcoming summer storms and the SXR80 not automatically obtaining WAN without intervention.
- jcharnetMay 25, 2021GuideThis seems to be a similar issue I have, whenever I power down the router, circuit breaker, power outages or just unplug the router, when power is restored the router doesn’t seem to turn on. No light shows up on the status bar, stays black. To get it back to work I have to unplug device, wait a few minutes (5-10m) and the plug the device back. Then I see the status light blink white and everything is back to normal. It does get the correct internet connection at that point.
Anyone have similar issues? Any way to fix it?
Thank you,
Joao.- JohnD333May 25, 2021Apprentice
Yes. After hours with tech support I gave up. Sent it back for refund and bought a new unit and set that up all over again.
better, but this forum shows how many flaky issues remain.
- jcharnetMay 25, 2021GuideAnd with the new unit you don’t have this issue? Unplug and plug back, and the router starts correctly?
