freer
May 19, 2021Guide
SXR80 Can’t Obtain IP Reliably After Power Cycle
I just purchased the Orbi Pro SXK80 (comprised of the SXR80 and a single SXS80). Since I have owned it, I have been doing work on the house and have had to flip the breaker at least once a day. Thi...
pierpox72
Jun 19, 2021Tutor
Hi, I’m an owner of a SXR80 (plus 4 SXS80) also with the firmware 3.2.6.100,I have the same issue of the user jcharnet.If I unplug the router from the wall outlet, I have to wait also hours (with the device unplugged) before to plug it again and finally see the white light on.This is an absurd behaviour for a device business oriented!Is there a fix to solve the problem?Or also a workaround to recover fastly the situation when, for example, a power outage happens?
RaghuHR
Jun 21, 2021NETGEAR Expert
If anyone still seeing the issue after the firmware 3.2.6.100 update then please send us the debug logs taken from local UI.
We will investigate further and provide a feedback.
Thanks,
Raghu
