sobandoq
Jul 22, 2024Aspirant
SXR80 does not connect with SXS80 satellite
Hello, I've spent hours trying to get the SXR80 to detect/connect with the satellite. In both the app and the web dashboard, it shows no satellites being connected. Under "Attached Devices", the SXS...
- Jul 22, 2024
Ok, if it's got same version of FW then should be ok to leave SXR where it's at.
Is this SXS is same room as the SXR? At 10-15 feet in between, if you factory reset both and setup from scratch using a wired PC and web browser to walk thru the setup wizard on the SXR, the SXS should get synced.
I tend to leave the system alone right after I've factory reset SXR and SXS and let the SXS auto connect and sync to the default wifi SSID name. Once there, the SXR setup wizard routine should find the SXS and complete adding it and the setup routine. I then will change the default SSID name to something else after I get to the home page on the SXR.
Jul 22, 2024Guru - Experienced User
Was the SXRs FW updated before the SXS by chance?
What happens if you ethernet connect the SXS to the back of the SXR?
sobandoq
Thanks for the reply, according to the app the router is running the latest 4.3.3.200
Unsure of how to check the SXS FW since it is not showing in the app. I tried to login into its IP but I have not been able to do so.
It is possible that one could have updated first, since I moved all equipment to a new location and ended up hard resetting the router, at which point it upgraded the FW.
If I connect them and go through the process of pairing, sometimes it shows a blue light but it still does not show on the app or interface. Most of the time it just fails to pair.
- FURRYe38Jul 22, 2024Guru - Experienced User
If the SXR had updated first, then you may need to downgrade the SXR back to prior working FW version. Long enough to see if the SXS will connect then, and if so, update the SXS manually to newest FW version, then update the SXR lastly.
- sobandoqJul 22, 2024Aspirant
So as I was figuring out how to change the FW, I connected my laptop to the SXS via ethernet and was able to login into it.
I can confirm that they are both on the same FW version and apparently also connected to the router.
Would still be worth downgrading the FW?
