Cafetom
Jan 26, 2022Star
SXR80 doesn't show up in older 2.4 wireless devices
SXR80 — Orbi Pro AX6000 WiFi 6 Tri-band Router / SXR80 Hello all, I can not figure out what setting to change to allow my older 2.4 wireless clients to see the wireless network. I have seemingl...
Jan 26, 2022Guru - Experienced User
I have the SXK30 and haven't seen that as an option either in the browser gui or in the insight management.
A couple things.
1. is the older devices able to see the network at all? Or can't see the ssid?
2. have you looked up the wireless card in the devices to see if you can get a driver directly from whoever makes the wireless card (not lenovo)
3. Some devices you could simply purchase a cheap usb-->wireless adapter and use.
4. if you have an old router sitting around, put it in access point mode just for the 2.4ghz.
Cafetom
Jan 26, 2022Star
1. older devices that I have seen, including mine, will see other networks, just not mine. They do not see my SSID. And when I tried to manually add the network as if it is a non-broadcasting SSID it still doesn't connect.
2. I have updated the drivers to the official lenovo drivers, and also updated it to try, with the Intel drivers, and also with the Windows drivers. None of them work
3. Sure, I can buy a wireless card for my device, I am thinking about my guests/customers. I can't really expect them to change or buy different devices for my network.
4. Hahaha. That is funny you should say that. I had 3 netgear routers serving the purpose of having multiple SSIDs (all with separate external IP space so the devices never routed between each other. The whole reason I got the orbi business was to do away with 3 separate routers and do more of a small business setup. Something tells me I should have trusted my friend when he said to spend the same amount and buy Ubiquiti. :(
- plemansJan 26, 2022Guru - Experienced User
You'd have ran into the same issue with Ubiquiti.
Its a problem of the drivers on the older devices going to the AX spec (wifi 6), not of the router itself.
wifi 6 was supposed to be backwards compatible, sadly it wasn't with some older devices.
And it is better to use a business grade one for a business. Nice thing is you can plug an old/cheap N300 router into it and put it on its own vlan through the settings so it won't jeapordize your setup.
Or don't worry about it a whole lot. Most devices made halfway recently function fine on AX standards. Tends to be the really older devices.
