sporz
May 20, 2024Aspirant
SXR80 intermitent
Hi, I'm experiencing intermittent connection over the wifi. But no flashing lights from the access point. From where can I start to investigate? Thank you
sporz
Hi,
Firmware: V4.3.3.200
The AP is connected to a Draytek router, which provides the DNS. The Internet provider is BT.
1 Satellite.
150 square mt on two floors
APs are 20 mt from each other
The issue is just with wireless devices
Channels:
2.4: Auto 6P + 10(S)
5: 44
There are many wifi: I can count 12 wifi signals. But they have always been there
Thank you
May 20, 2024Guru - Experienced User
Is the SXR running in router or AP mode?
If your ISP modem already has a built in router and the SXR is in router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Try 10 meters between the SXR and SXS.
Try channels 1 and 40 or 11 and 48.
- sporzMay 21, 2024Aspirant
Hi ]
Thank you for your help
The SXR is set as Access Point
I've changed the channels to 1 and 40.
Another thing I've been told from yesterday evening's update is that the LED sometimes goes pink. Does this highlight something else?
- FURRYe38May 21, 2024Guru - Experienced User
Ya, means that the upstream router is not giving good internet services to the SXR due to unknown reasons, or bad cabling or something on the SXR not working right.
How is the SXR configured for AP mode? Dynamtic or Static IP configuration? Static is recommended.
- sporzMay 29, 2024Aspirant
Hi,
New update.
I was able to investigate further and understood that the Satelite was causing the issue.
When I turn it off, the connection is solid around the place, except for those not covered by the main AP.
I reset the satellite, but after reconnecting it, the problem persisted again. Any idea?
Thank you
