Pardman
Jul 14, 2021Tutor
SXR80 Orbi Pro Ethernet Ports Not Working
Hi - Setup: One SXR80 Orbi Pro Router with the latest firmware installed Three SXS80 Orbi Satellites with the latest firmware installed Wifi network works fine and connects to internet Thre...
Aug 01, 2021Guru - Experienced User
What happens if you keep PPPoE on the ISP modem, use the modem and the host router, then connect the SXR to the modem, with out any PPPoE or VLAN configuration. Be sure the SXRs IP address doesn't conflict with the modems IP address if it uses 192.168.1.1. The SXR should auto change.
I'd factory reset the SXR and setup from scratch using a wired PC. You should be able to see the setup wizard at 192.168.1.1 in a web browser on the wire connected PC. Walk thru the setup wizard and complete it. Can you again access to the internet after it completes?
