Technofuzz
Jul 20, 2021Aspirant
SXR80 Orbi Pro Wifi 6 LAG + Ethernet Backhaul config ?
Hey all, new to the LAG setups and was just wondering if the SXR80/SXS80 allows for an ethernet backhaul to the satellite over 1Gbps via LAG and what the connection setup should look like. I was j...
Technofuzz
I would point out that I am using this for a home network, so at the present time i have little use for VLANs for IoT, etc. I will most likely add a 2.5G switch for my desktop and other PCs in the game room, but i am currently not sure how to set up the ethernet backhaul, the documentation provided by netgear does little to clarify things. Do I set ports 2 and 3 as a LAG and connect them to the satellite (i will only have one satellite and dont plan to add more). I do reliaze that LAG from the modem is an option, just trying to figure out if ethernet backhaul is supported over LAG to obtain 1gbps+ speeds as the game room will be attached to the satellite via ethernet on the 2.5G port.
Again thank you for taking the time to help.
Techno
schumaku
Jul 21, 2021Guru - Experienced User
With the pre-requirement that both LAN ports for the LAG (the manual just remined me that it is possible to define two LAG groups, not just the one on the marked ports, it says "LAN ports 2 and 3 can form one link aggregation group (LAG). LAN ports 4 and 5 can form another LAG." p.12) being in the same VLAN group, the Orbi Pro WiFi 6 AX6000 Tri-band WiFi System (SXK80) User Manual "Manage Link Aggregation", p.135 ff. does decribe the process.
- TechnofuzzJul 23, 2021Aspirant
I understand how to setup a LAG, I was just trying to clarify if the router/satellite support ethernet backhaul over the LAG (theoretical 2gbps) connection. Sorry if I seem less educated on this networking front, as I do have a CS degree, I've never dabbled this far into networking topology. This is my plan, just trying to see if it's feasible/possible. Router ->(LAG) (2gbps) -> Satellite (from 2.5gbps port on satellite) -> 2.5Gbps switch -> 2 PCs in gaming room (to recieve 1.2Gbps internet download speeds). I do understand that LAG does not mean it will increase my speed 100% from 1gbps -> 2gbps, but will provide some increase in overall network speed.
Thanks Again
Techno.
