elbobbah
Nov 03, 2024Tutor
SXR80 satellites both have lost connection, re-adding is not possible with strange behaviour
I have already created a ticket for this, but maybe someone on the forum can also advise. This is what I have sent to Netgear: Today out of the blue I had no internet anymore on many of my devic...
Nov 04, 2024Guru - Experienced User
What modem/gateway is the router connected to?
solid magenta indicates either a backhaul issue or issues getting an IP address. If the router is having issues getting an IP address from the gateway, it could cause issues.
elbobbah
Nov 04, 2024Tutor
Hi, same update here as to netgear support;
What I tried in the meanwhile is re-flashing latest firmware but this did not help.
Just performed a factory reset of the router by holding reset for 30 seconds while on power, 30 seconds without power, replugging it to power and keeping another 30 seconds.
After this I tried the re-synch proces.
It seemed all was working, however after 10 minutes, satellites back to magenta.
No connection with my macbook, even when next to the router.
Keep going from searching
to warning (no internet)
I have 2 vlans and wifi (normal and iot). It seems I can connect to the iot 2.4 and 5Ghz network (when next to the router) and have internet access.
Netgear insights show (like it did before) the 2 satellites in red.
Every component is in the same place as it has been for more than a year.
Summary:
- No connection to main wifi (from mac or windows device)
- Connection to wifi of iot is working (with internet access), when next to router
- Satellites lose connection after reset/resynch and turn magenta
