elbobbah
Nov 03, 2024Tutor
SXR80 satellites both have lost connection, re-adding is not possible with strange behaviour
I have already created a ticket for this, but maybe someone on the forum can also advise. This is what I have sent to Netgear: Today out of the blue I had no internet anymore on many of my devic...
Nov 04, 2024Guru - Experienced User
Was FW on the SXS updated first before the SXR was?
What FW is loaded on the system?
Did you try to add the SXS one at a time?
Try using the SXRs add satellite feature on it's web page.
- elbobbahNov 04, 2024TutorThere was no manual update, so I don't know when which SXS or the SXR was updated. SXS's were added one at a time. I am now trying to force them both into an ip address. They were added from the web page. Running firmware V4.3.3.200 I have now changed the IP address of one of the 2 satellites to 192.168.1.201 and left the other one offline. It seems to be running ok for 2 hours now. Have connected the second one again just now, which now gets IP address 192.168.1.43. Both have backhaul to the SXR80. Will see if it stays stable in the coming hours. Don't know what has happened ...
- FURRYe38Nov 04, 2024Guru - Experienced User
So you can access the SXS web pages at those new IP addresses correctly?
FW same version as whats on the SXR?
Yes exactly the same. Are both up now and not going down again. Also have separate sets of devices connected, where before i could see the devices of the SXR in the SXS page.
Have a feeling something messed up the mac addresses by which they both registered the same way.
Very strange, since this all happened while just watching tv ...
