jso1
Sep 26, 2023Aspirant
SXR80 SXS80 4.3.2.100 - Ethernet Port Issues
I have an SXR80 and SXS80 on my home network. When connected directly to the ethernet ports, I get approximately 150-300 Mbps connection speed maximum. My internet is well over a gigabit (the ...
jso1
Sorry, meant to post this in the main channel, not the Beta forum. Not sure if someone can move it.
schumaku
Sep 26, 2023Guru - Experienced User
Better create a new post on the Orbi Pro section, and include more details on how you linked up the WAN/Internet connection, if you re using to links in a LAG to the cable modem for example, or if you have connected a single WAN device operating on a 2.5 GbE link. how else you should ever get whatever speed (Speedtest on the Orbi Pro direct?) speeds beyond of 1 GbE?
