CHCarlos's avatar
Feb 25, 2024
Firmware Version 4.3.2.100 BUG
Hi all
What's about this problem. I sink I have the same issue.
Is an update on the queue?
Kind regards
Carlos
  • The 4.3.3.200 Release notes show
    • Fixes an issue where the device that is connected on Ethernet to SXR80 or SXS80 does not come UP for approximately 30 seconds.
    Could this be the DHCP issue or connection delay you experience?
  • FURRYe38's avatar
    What orbi model # are you referring too?
    Need more details on what this problem is?
    CHCarlos wrote:
    Hi all
    Kind regards
    Carlos
    • CHCarlos's avatar
      CHCarlos
      Guide
      Hi,
      Sorry for the delay.
      I have the AX6000 WIFI Mesh Router (SXR80) with to satelites SXS80.
      The problem is that the DHCP Request from PC's LAN wired are very slow 10-30s.
      This problem is coming with the news firmware release.
      Kind regards
      Carlos
      • FURRYe38's avatar
        What is the brand and model# of the ethernet adapter in the PCs?
        Be sure any ethernet adapter drivers are up to date from the ethernet mfr.
