hawkinsR
Jun 13, 2023Aspirant
SXR80 w/ Wavlink WL-WN573HX1
Does anyone know if the Wavlink WL-WN573HX1will work inmesh extendermodewith the SXR80 router?
schumaku
Jun 14, 2023Guru - Experienced User
This is what the https://www.wavlink.com/en_us/product/WL-WN573HX1.html FAQ says:
Is the Wavlink Everything Mesh WiFi system compatible with other mesh systems?
The Wavlink Everything Mesh WiFi system is a proprietary mesh system and is not compatible with other brands of mesh networking systems. If you have purchased several Wavlink Everything Mesh devices, you can interconnect them to create an overall mesh network covering a wider area.
Said that, the same applies to the Netgear Orbi Pro WiFi 6 systems.
