hawkinsR
Jun 13, 2023Aspirant
SXR80 w/ Wavlink WL-WN573HX1
Does anyone know if the Wavlink WL-WN573HX1will work inmesh extendermodewith the SXR80 router?
schumaku
Jun 15, 2023Guru - Experienced User
Network cables are the much better approach to create a switched and wired backhaul than praying some WiFi backhaul might lead to a substandard result on reliability and effective throughout - for all satellites.
hawkinsR
Jun 15, 2023Aspirant
I agree, but just running cables settles the wifi situation how, since the cameras are all wifi and the added benefit is for those that want to work outside...
- schumakuJun 15, 2023Guru - Experienced User
The cable from the router (or for the sake of a core switch if you like) to the satellite installed outdoors towards the garden does bypass the (likely weak) wireless backhaul hop. From the satellite to the camera you can of course continue the obvious wireless connection required.
- hawkinsRJun 22, 2023AspirantSo what outdoor net gear product will work with my system, I do not believe this was ever answered sufficiently or would that aforementioned unit works as a Wi-Fi access point if it was hardwired
- schumakuJun 22, 2023Guru - Experienced User
Following your indication that the outdoor Wi-Fi coverage is very limited, there is not much hope for a chance to bring up wireless backhauled access points in your environment. So yes, no better options available than installing wired access points - for simplicity retaining Orbi Pro WiFi 6 management compatibility - installing in a weather proofed outdoor wifi enclosure.
