kwarwic
Jan 28, 2025Aspirant
SXR80 with GS308E - Connect SXS80 directly to SXR80 or vial port on switch in VLAN set up
SXR80 + SXS80 + two SXS30 sats all running fine via wired backhaul. We have several switches MODEM SXR80 (patch cabled to switch in closet) GS308E (patch cable to all wired locations - Sound b...
kwarwic
Thanks!... This rookie mind needs to digest that and I'm leaving for a day and a half... I'm sure I'll be back with a follow up question đ or two or three. Appreciate the heads up.
Jan 28, 2025Guru - Experienced User
Sounds good. Try not to over think it. Just make it simple as possible. I've found that non managed/smart switches work best for ethernet connected Orbi systems.
