ranale's avatar
ranale
Follower
Jul 16, 2021
SXR80 with Wifi5 Orbi Pro Satellites
From a support article I found, it appears that the Wifi6 Orbi Pro Router (SXR80) is not compatible with the Wifi5 satellites (SRS60 and SRC60).  Does that apply to Ethernet backhaul as well, or only Wifi backhaul.  I would like to replace a damaged SRR60 with an SXR80, and 100% of my backhaul links are Ethernet.
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    ranale,
    Welcome to the community! :)
    It applies on both Ethernet backhaul and WiFi backhaul.  The Orbi Pro WiFi 6 devices cannot be paired and therefore, incompatible to work with Orbi Pro WiFi 5 devices.
    DaneA
    NETGEAR Community Team
ProSupport for Business
