wayneker
Jan 28, 2023Aspirant
SXS80 LAN port extremely slow
I got Orbi Pro SXK package for home use. Wifi works very well. However, my LAN ports on the satellite has many problems with my Mac mini. I have tried all LAN ports with my Mac mini and the problems ...
Jan 29, 2023Guru - Experienced User
If everything else works fine, I'd be more suspicious of that specific device.
Have a usb--ethernet adapter or wifi adapter you could connect it to and try it with?
- waynekerJan 29, 2023Aspirant
initially, I thought the problem is that device as well.... But It can connect to Internet at around 700-900Mbps. The weird part is.... it takes awhile to "get to" a website, I guess the technical term is ping? P2P is extremely slow around 9Kib/s.... Does the Pro version of Orbi have restricted access to P2P traffic on the LAN port? are there settings to enable P2P traffic on LAN ports?
- hermesromerorJan 30, 2023Apprentice
The satellites are connected to the main router using wire or wireless?
- waynekerJan 30, 2023AspirantAll wireless connection to router
