wayneker
Jan 28, 2023Aspirant
SXS80 LAN port extremely slow
I got Orbi Pro SXK package for home use. Wifi works very well. However, my LAN ports on the satellite has many problems with my Mac mini. I have tried all LAN ports with my Mac mini and the problems ...
wayneker
Jan 29, 2023Aspirant
initially, I thought the problem is that device as well.... But It can connect to Internet at around 700-900Mbps. The weird part is.... it takes awhile to "get to" a website, I guess the technical term is ping? P2P is extremely slow around 9Kib/s.... Does the Pro version of Orbi have restricted access to P2P traffic on the LAN port? are there settings to enable P2P traffic on LAN ports?
hermesromeror
Jan 30, 2023Apprentice
The satellites are connected to the main router using wire or wireless?
- waynekerJan 30, 2023AspirantAll wireless connection to router
- hermesromerorJan 30, 2023Apprentice
I would say this is the issue. You tried connected to the the ports of the router? Try connecting wirelessly to the satellite (be sure it is) and do a speed test (fast . com), If it is as slow as connected to the lan port, the issue is the backhaul speed.
