wayneker
Jan 28, 2023Aspirant
SXS80 LAN port extremely slow
I got Orbi Pro SXK package for home use. Wifi works very well. However, my LAN ports on the satellite has many problems with my Mac mini. I have tried all LAN ports with my Mac mini and the problems ...
wayneker
Jan 30, 2023Aspirant
hi bruce
1 speed test of internet traffic is very fast
2. only have tried to connect to satellite as my cable isn't long enough to reach the router. (I can't move my Mac mini as it is a modified with linear power supply and it's connected to a huge power supply on my audio rack)
3. I have used Transmission and qBittorrent and both are very slow with LAN port. I also tested it with Wifi on Mac mini and it seem the problem is the same? Not completely confirmed as I only tried briefly. Perhaps it's the setting on my Mac?
BruceGuo
Jan 31, 2023NETGEAR Expert
If testing via wireless or wired having the same problems, I would suggest use another AP to test with your MAC to make sure Mac itself is fine.
Do you have another AP, or use your mobile as hotspot to confirm if the result is consistent. If consistent, it should be Mac problem.
