david85297
Jul 21, 2021Star
SXS80's using channel 157 to connect to SXR80. Can't change it?
I have a Orbi SXS80 Sattellite dropping its connection to below 5Mbps to the SXR80. Sometimes throughout the day it works great, then during congested periods it drops to nothing. I've noticed that t...
JohnC_V
Jul 27, 2021NETGEAR Employee Retired
5ghz-2 channel is for the wireless backhaul radio channel. It cannot be changed as it is the only channel used for satellites. It would be best if you can try to use 3rd party software to detect other radio channels that interfere with your network.
John
NETGEAR Team
Mstrbig
Aug 12, 2021Master
John
NETGEAR Team
Where are these settings? I don't see them on 3 different Orbi Pro network setups.
