DurkW
Dec 31, 2020Follower
TIVO Roamio streaming
I've installed my Orbi Pro. Everything works except Tivo Stream. Error on iOS app says "There was a problem connecting to your streaming device . . ."
DaneA
Feb 10, 2021NETGEAR Employee Retired
Kindly try to upgrade the firmware of your Orbi Pro devices to v2.6.0.108 then check if the same problem will occur. You can download firmware v2.6.0.108 here.
DaneA
NETGEAR Community Team
stevethompson
Feb 11, 2021Star
I have a similar problem with my Roku Streaming Stick. Connects via WiFi but no internet. Finally got it to work by assigning it a static IP address. Well it’s been working for a couple days now.
