steveo337
Dec 16, 2020Follower
Two Orb Routers 7 satellite
Hello,
I have had a 3 Orbi Pro System running in our office for some time now, So pleased with it I bought a 6 pack for our small warehouse. Question is, can I run all these units together if I use LAN, I know they say 6 is max for daisy chain, but if I am not using a mesh style and running ethernet to each.
If not can i lock satelliteto certain routers? If i go into of the routers it will say that the satellite is connected to what ever router i am logged into.
Thanks.
6 is max because we tested and evaluated in the worst case. Actually, we don't have limitation for 7th satellite.
After a satellite is paired with a Base, it will only connect to the Base (The system) and cannot connoect to other Bases.
1 Reply
- BruceGuoNETGEAR Expert
