MartijnS
Oct 23, 2021Guide
Ultraslow Wifi on 2.4 Ghz
Hello I have the following setup ISP router (Ziggo) -> SRR60 as AP -> 5x SRK60 (3x wired, 2x wifi) and 1x SRC60 (wifi) -> wifi and utp clients -> unmanged switch ...
Oct 27, 2021Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
If seen, Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
- MartijnSOct 27, 2021Guide
Hi,
Thank you for your reply
I have 2 setups
1:
One floor of 22.500ft2 with 1 router and 6 satellites of which most are wired (2 are wirelessly connected)
We have split (because if this) the 2.4 and 5. The 5 Ghz is working pretty much perfectly at 600-700mbps (max provider speed)
Max distance is about 50ft most with a direct line of sight
2:
2 floors approx 1.200ft2 with 1 router and 2 satelliets, both wirelessly connected
Again 5 Ghz is working fine at 300 mbps (max provider speed)
2.4G Channel Auto ( 13 )
2.4G Mode Up to 400 Mbps
5G Channel 36(P)+40+44+48
5G Mode Up to 866.7 MbpsAdvanced Wireless Settings (2.4GHz b/g/n)
v Enable SSID Broadcast
v Enable 20/40 MHz Coexistence
v Enable WMM (Wi-Fi multimedia) settingsCTS/RTS Threshold (1-2347) 2347
Preamble Mode Automatic
Transmit Power Control 100%Advanced Wireless Settings (5GHz 802.11a/n/ac)
Backhaul Topology
v Enable Daisy-Chain TopologyAfter enabling Beamforming and MIMO on location 2, the speed was the same unfortunately (@3 feet from the satellite)
I have tried switching band as it is pretty busy, but the result remains the same.
Close the router I can get 50mbps which is still not great.
I will try the same settings tomorrow on location 1
Thanks for the help, but I don't think we are there yet.
- Apr 05, 2020Retired_Member
