NortheastGuy
Mar 23, 2021Star
Understanding Communication Across VLANs w/ Orbi Pro
Hi! I'm trying to understand how communication works across VLANs with the Orbi WiFI 6. If I have a printer on SSID 2 (Employee network), can an iPhone on SSID 1 (default) access it? Can that same...
schumaku
Mar 29, 2021Guru - Experienced User
The point is that you could print if the system does support a printer configuration using an iP address.
Trouble is that common discovery mechanisms like Bonjour or UPnP SSDP (and broadcast based stuff like proprietary or SMB protocol printing) don't go beyond of the same network (IP subnet, VLAN, ...).
- bredwardJul 10, 2021Tutor
The beta firmware v3.2.5.778 supports mDNS accross VLANs: https://community.netgear.com/t5/Orbi-Pro-Beta/In-Beta-SXK80-Beta-firmware-version-3-2-5-778-for-mDNS-service/m-p/2102249/highlight/false#M27
