askvictor
Aug 03, 2022Initiate
Using a non-Orbi-pro device as an extra WAP
I've got an Orbi pro setup (SRR60 + SRS60). Is is possible to extend the wifi network using a non-Orbi WAP (I have a couple unused so was thinking of utilising them), if I connect the WAP to the rout...
Aug 04, 2022Guru - Experienced User
You can set it with the same ssid/password but it won't be as efficient at roaming as the orbi system as a whole.
You'll also want to set it on a different wireless channel so it isn't creating interference with the orbi
