JBQuinnforRCRC
Jan 22, 2025Aspirant
Using DHCP Rather Than Static Adress to Hook To Internet Using Orbi SXR30
We have an ORBIPro SXR30. Currently it hooks to the internet through a Fiber modem. It uses a static address for the IP Gateway on the router WAN settings. We are changing services. The new se...
Jan 22, 2025Guru - Experienced User
You should be fine.
Unless you're using the static public IP address (different from private) for outside services/servers
