NemoNeil
Apr 28, 2022Guide
VLAN Configuration when you have a Switch in your Network?
Hi I have the SXK80 Router and Ethernet Port 1 is connected to Modem(Internet) which has default VLAN 1 assigned and Ethernet Port 2 is connected to a 4 port switch and configured to VLAN 2. Port 3...
JeraldM
May 03, 2022NETGEAR Employee Retired
Welcome to the community!
For your requirement, you would need inter-VLAN routing which isn't supported on the SXR80.
In that case, we suggest raising this on our Ideas Exchange section here.
JeraldM
NETGEAR Community Team
NemoNeil
May 03, 2022Guide
Thanks Jerald
Its a shame you dont get this out the box! I paid £1000+ for a business wifi router router and doesnt allow you to creat rules to allow you to talk to other vlans (inter-VLAN routing)
Bit disappointed and will consider returning this. I see others have also suggested inter-VLAN routing in the suggestions and nothings been implmented to date?
anyway, appreciate your response
Thanks
- BruceGuoMay 03, 2022NETGEAR Expert
Assume Router is in "Router mode".
WAN is connected with a modem
LAN1 is with VLAN2.
The switch is under VLAN 2 so camera, printer, computer are under VLAN 2 as well.
I guess you consider camera is an IOT device. So you want to assign VLAN3 IP to the camera. Then, PC under VLAN 2 can communicate with camera under VLAN3?
If my understanding is correct, you need to configure:
downlink port of SXR80 in trunk mode and with default VID.
Configure uplink port of the switch in trunk mode.
Configure VLAN3 in the port that camera connects to
Configure VLAN2 in the port that Printer and PC connect to
It make sure the uplink port and downlink port can forward tagged packet without modification. Then, PC and camera can communicate when they are in different subnets.
Router can route the packets.
Bruce
- NemoNeilMay 03, 2022Guide
Hey Bruce
So router is in Router Mode
To simplyfy :
Port 1 = Connected to ISP Modem = VLAN ID 1 (Trunk Mode)
Port 2 = Connected to an unmanaged 4 port Switch = VLAN ID 2 (Trunk Mode)
- SWITCH PORT 1 = CCTV
- SWITCH PORT 2 = HIVE Heating
- SWITCH PORT 3 = Printer
- SWITCH PORT 4 = EMPTY
Port 3 = Connected to PC 1 = VLAN ID 3 (Access Mode)
Port 4 = Connected to PC 2 = VLAN ID 4 (Access Mode)
I assume I cannot assign VLAN's to the devices on the Switch and would require a Managed switch? The Orbi Pro cannot do this?
Also if I want to set specific rules on Inter-VLAN communication, i cannot do this as Jerald mentionedHope this makes sense
- BruceGuoMay 04, 2022NETGEAR Expert
Correct. Orbi Pro can only assign VID to its ports. If you hope devices under a switch to have different IP subnet, you need to use a managed switch, which has to support 802.1q protocol. In fact, VLAN function implies VLAN features are required in all devices between Orbi Pro and clients. So far i don't feel you need a static route to help inter-VLAN communication. Image that, a client under VLAN 2 can talk to another client under VLAN 3 because packets are route via Orbi Pro, which owns the gateway for VLAN 2 and 3, so the router already know how to route the packets!
For buying a switch, you can take a look in this page. If you need recommendations, please let us know.
https://www.netgear.com/business/wired/switches/fully-managed/
